Date/Time: Thu, 31 Oct 2024 10:12:42 +0000
Sierrachart does not make a dll file from custom study
View Count: 50
[2024-10-30 14:19:32] |
User58776 - Posts: 16 |
So I wanted to make 2 custom studies. The first study everything went ok, sierrachart created the dll file and it works. For the second study, the build doesn't work. I don't get an error message but the dll just won't create. And hence the study does not show up. Any ways how to know what is the problem. This is the log: |
Private File |
[2024-10-30 19:11:12] |
ForgivingComputers.com - Posts: 952 |
Make sure there are no spaces in the filename.
[2024-10-31 06:22:55] |
Sierra_Chart Engineering - Posts: 16766 |
Are you using Remote Build? If so, we need to see the output of the Remote Build operation.
[2024-10-31 09:09:55] |
I have solved it in the meantime. Sorry for the inconvenience.
