Date/Time: Thu, 31 Oct 2024 10:13:06 +0000
VbP Visible Bars
View Count: 29
[2024-10-30 13:56:45] |
User781731 - Posts: 19 |
On the VbP Visible Bars study, is it possible to have the "Volume Numbers Text" display on the left side of the volume bars, rather than inside them? See screenshot for the yellow X's that show the location I'm wanting to put the numbers.
Screenshot.png / V - Attached On 2024-10-30 13:54:15 UTC - Size: 56.26 KB - 17 views |
[2024-10-30 16:03:20] |
John - SC Support - Posts: 35639 |
Refer to the following Input: Volume By Price Study: Align Volume Numbers to Base of Volume Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
