Date/Time: Sun, 24 Nov 2024 04:33:37 +0000
Update
View Count: 65
[2024-10-29 18:57:24] |
Dennis B. - Posts: 272 |
On the first of the month I do the update to avoid the pro fees. This month I will be a little late because I'm waiting for a computer part is that ok? Also, I went to make a payment through my debit card and it went through Paypal instead. I don't want to use Paypal because of security issues.
[2024-10-29 19:37:42] |
If you are not able to connect to your live account, then you will not be able to get the real-time data. You will continue to get the real-time data until your "Verified Until" date, which is currently showing as October 31, 2024. After that date, you will not be able to get the real-time data until you make that connection. We are removing Stripe as one of our payment processors, so you will have to use PayPal. You do not need to create a PayPal account, or have one, you can just pay with the credit card just like with Stripe. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
