Date/Time: Wed, 27 Nov 2024 12:34:27 +0000
Rithmic papertrade issue
View Count: 1178
[2014-09-08 00:52:42] |
User14266 - Posts: 225 |
Rithmic Trading | Port for executable: 25281 | 2014-09-07 19:49:25 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-07 19:49:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 25281 | 2014-09-07 19:49:27 Socket (1748) | Connected. | 2014-09-07 19:49:27 Rithmic Trading | Connected to server. | 2014-09-07 19:49:27 Rithmic Trading | Sending logon request message. | 2014-09-07 19:49:27 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-07 19:49:27 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-09-07 19:49:27 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-09-07 19:49:27 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-09-07 19:49:28 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-09-07 19:49:28 Rithmic Trading | Server Alert: PnL Connection Broken | 2014-09-07 19:49:28 Rithmic Trading | Server Alert: Intraday History Connection Broken | 2014-09-07 19:49:29 Connection timed out. Will disconnect and retry. | 2014-09-07 19:51:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-07 19:51:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-07 19:51:25 Socket (1748) | Shutdown and closed. | 2014-09-07 19:51:25 Rithmic Trading | Disconnected from the server. | 2014-09-07 19:51:25 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-07 19:51:25 |
[2014-09-08 03:38:15] |
birdaa - Posts: 12 |
This is down for me also
[2014-09-08 05:52:28] |
Please contact your broker/trading service about this issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-08 16:17:20
[2014-09-08 10:32:36] |
User75432 - Posts: 1 |
same issue.
[2014-09-08 16:17:09] |
Are you still having the problem?
[2014-09-08 16:17:59] |
No, it is fixed now.
