Date/Time: Sun, 24 Nov 2024 05:08:53 +0000
Market profile (TPO) instead of Volume profile.
View Count: 77
[2024-10-29 15:39:36] |
the white rabbit - Posts: 22 |
Hi I would like to display the market profile (TPO) instead of the volume profile on my chart while trading. However, the candles disappear while applying the TPO on the chart. Is there a way to do this? Thank you |
[2024-10-29 16:14:23] |
There is not a way to view the TPO and candles at the same time. You would need to have 2 different charts for this.
[2024-10-29 16:40:09] |
thank you for your reply. but is there a way to overlay the TPO profile on the chart? I TRIED THE OVERLAY STUDY BUT DIDN'T WORK. |
[2024-10-29 17:57:53] |
There is no option in which you can view candles with the TPO. The TPO uses a special time scale, so this can not be done. You can come close to the idea of the candles by viewing the TPO with "Letters/Blocks in Own Column". This will give you each letter that makes up the sub-period as essentially a candle. You can then mark the open of each sub-period to view that specific item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
