Date/Time: Sun, 24 Nov 2024 05:06:38 +0000
Alerts based on Spreadsheet cell values?
View Count: 65
[2024-10-29 14:46:27]
ycomp - Posts: 317
is there a way to make an alert which will display an alert when a cell value in a spreadsheet is TRUE?
[2024-10-29 15:47:00]
Sierra Chart uses a context of zero is the same as False and any non-zero value is True.
Therefore, to test if a cell is true, you would just test if it is non-zero, such as "=K3 <> 0".
If you are doing this in an alert, you would need to reference the subgraph of the spreadsheet column and then your alert formula would look like the following:
=ID1.SG1 <> 0
