Date/Time: Sun, 24 Nov 2024 04:21:23 +0000
Default Chart Bar Spacing disabeled
View Count: 77
[2024-10-29 11:25:37] |
User757816 - Posts: 17 |
Hello, I would change the default space between two bars, set as splitted ask bid, in order to better visualize the totalò volume numbers and bars (attached picture 1). I tried to change the Default Chart Bar Setting in Global Graphic Setting but it not saved the new value. Once I try to change it in the specific Chart it is disabled (picture 2). Please could you help me on this? |
Screenshot 2024-10-29 122210.png / V - Attached On 2024-10-29 11:22:32 UTC - Size: 99.34 KB - 21 views Bar Spacing Disabled.png / V - Attached On 2024-10-29 11:25:06 UTC - Size: 25.2 KB - 25 views |
[2024-10-29 15:40:20] |
The reason some of the options are grayed out in the "Graphics Settings" is that you have chosen the Chart specific Graphics Settings, and those items can only be controlled through the Global Graphics Settings. To change them, you would need to select "Global Settings >> Graphics Settings". But, from what you are describing, we do not think that is the issue. It sounds like you just need to expand the bar spacing for your chart. Refer to the following: Working With Charts: Changing Bar Spacing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
