Date/Time: Sun, 24 Nov 2024 04:59:09 +0000
[User Discussion] - Imbalances not representing reality problem - reference attached
View Count: 107
[2024-10-29 11:15:58] |
xDeHn - Posts: 9 |
Actually I'm struggling with footprint. These are my needs (I attached my main references): Bid || Ask > Default text color black > Default background light grey - Delta ↔ horizontal (cell background color) BID –(minus) ASK & VICEVERSA | 1-2-300 size steps ↔ ±darker = ±big number – - Tot. Volume POC: outline Yellow. - Minimum for coloration: 50 contracts IMBALANCES (bold text): - DIAGONAL 4-3-2 times size steps in diagonal ↗↙ | ±thicker = ±big number. - Text color: [BID] Dark Violet > Violet || [ASK] Light blue > blue // ±darker = ±big number. Other settings I need to set-up are in second attachment. Actually I need to focus on FP first. |
FP Classic.png / V - Attached On 2024-10-29 11:10:18 UTC - Size: 496.81 KB - 31 views Attachment Deleted. ChartBooks Settings Req_DL.pdf - Attached On 2024-10-29 11:14:00 UTC - Size: 510.42 KB - 24 views |
[2024-10-29 15:37:18] |
We have no idea what the issue is that you are having from your post. What exactly is your problem?
[2024-10-29 19:02:57] |
xDeHn - Posts: 9 |
It's actually okay sir John, I find out an alternative solution. It's by far away from the previous attachment but at least it's readable.
Unlucky Solution.PNG / V - Attached On 2024-10-29 19:02:54 UTC - Size: 136.16 KB - 16 views |
