Date/Time: Sun, 24 Nov 2024 04:25:28 +0000
Can't access custom study
View Count: 58
[2024-10-28 20:30:10]
User944318 - Posts: 2
Was able to code and successfully build a custom study, however, when I open the "add custom study" I get the messages in the log: "Found DLL: strategy_64.dll", "Found DLL: UserContributedSTudies_64.dll", "No custom study function names found in .../Data/Strategy_64.dll", "InternalVersionNumberToFIleNameMap is empty for strategy", "Closest math for .../Strategy.dll returned empty result".
[2024-10-28 20:36:46]
It sounds like you did not specify the "SCDLLName()" function in your study. Refer to the following:
How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions
