Date/Time: Thu, 31 Oct 2024 10:12:46 +0000
Intraday Data for DOM
View Count: 96
[2024-10-28 19:26:28]
BTMtrader - Posts: 1
I am wondering what is the reason when i switch off my PC during the day some data are missing on DOM, The missing data are:
- Current traded ASK volume
- Current traded Bid volume
is this related to Data package i purchase or another reason?
Thanks,
imageDOM SC.png / V - Attached On 2024-10-28 19:26:21 UTC - Size: 36.19 KB - 14 views
[2024-10-28 20:26:57]
John - SC Support - Posts: 35639
The Current Traded Bid/Ask is not persistent. So any time you exit from and then restart Sierra Chart, those columns are going to be cleared and start from nothing.
[2024-10-29 19:53:20]
User496868 - Posts: 10
is there a way to make them from session start to end and not reseted
[2024-10-29 20:04:41]
The only way to do that would be to keep your system running at all times and then to manually reset the columns at the start of a session.
What you are wanting can be gotten by using the "Volume by Price" study. Keep in mind, the "Current Bid/Ask" columns in the DOM show the actual traded quantities at each price level. You can view that in a Volume by Price study that is setup to show the most recent session and display the "Bid x Ask" volumes for each price level. Refer to the following:
Volume By Price Study: Display Volume in Bars
[2024-10-30 12:59:07]
is there a way to give the bid and ask volume bars that comes out of the middle and have it look like the current bid/ask function
[2024-10-30 16:00:21]
We are not understanding this question. What do you mean by "give the bid and ask volume bars that comes out of the middle"?
[2024-10-30 16:07:53]
i mean add volume bars to the bid and ask columns that are side by side snd connected at the base
imageצילום מסך 2024-10-30 180640.png / V - Attached On 2024-10-30 16:07:22 UTC - Size: 100.48 KB - 4 views
[2024-10-30 16:23:55]
You can setup 2 separate Volume Profiles with one set to display based on the Bid and the other the Ask and then display the Bid and Ask volumes in their respective profiles. The only thing you can not do is have the profiles back-to-back like you show in your image. The profiles would need to be right-aligned in order to get them to display together on the right side of the chart.
[2024-10-30 16:38:39]
so i cant make them look like this?
[2024-10-30 18:07:58]
Not exactly.
[2024-10-30 20:21:49]
can i have them be back to back
[2024-10-30 21:49:55]
Refer to our answer in post #8.
