Date/Time: Wed, 27 Nov 2024 13:05:04 +0000
SP and NYSE Total Volume
View Count: 1720
[2014-09-08 00:04:14] |
User16114 - Posts: 153 |
Not sure if I have something wrong or not. When I do a 30m chart of the SP and NYSE Total Volume (symbols TVOL-SP and TVOL-NYSE) Mondays and the first day after a holiday do not chart correctly (see attached pic). http://www.sierrachart.com/image.php?l=1410133709975.png |
[2014-09-08 14:16:47] |
actually looks like the first day after weekends and holidays volume starts charting from zero but subsequent days initial print and charting start much higher.
[2014-09-08 16:29:06] |
This is going to be dependent upon the Session Times in the chart. What are Chart >> Chart Settings >> Session Times set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-08 16:29:19
[2014-09-08 17:58:09] |
chart above is using Start Time: 09:30:00 End Time 16:29:59 NY Time (09:30:00 to 15:59:59 and 09:30 to 16:14:59 results in the same issue).
[2014-09-09 05:39:39] |
If you set the start time to 0:00, the volume should start at 0.
[2014-09-09 21:38:03] |
When I change Start Time to 00:00, symbol TVOL-NYSE picks up night volume for some days (see chart link below). http://www.sierrachart.com/image.php?l=1410298268302.png How do I create a 30 minute chart of regular trading hours (09:30 to 16:29:59) volume for symbol TVOL-NYSE. |
[2014-09-10 00:48:40] |
We do not see how logically that can be done with that symbol.
