Date/Time: Thu, 26 Dec 2024 14:35:09 +0000
Evaluation package will end on 30th October
View Count: 135
[2024-10-28 08:05:45] |
User807393 - Posts: 2 |
I do not understand that I ever booked evaluation package 12 which. I only bought package 11 and want to stay with it. Why I get requestet for it in 2 days? What is the reason for it.
Current service package.png / V - Attached On 2024-10-28 08:04:51 UTC - Size: 35.74 KB - 38 views Current service package.png / V - Attached On 2024-10-28 08:05:10 UTC - Size: 35.74 KB - 32 views |
[2024-10-28 15:04:26] |
John - SC Support - Posts: 36850 |
At some point, you must have selected the option to Evaluate Package 12 on your Account Control Panel. The only difference between package 11 and Package 12 is that package 12 allows you to view the Market by Order data. If you are not using that, then this will not have any impact on what you are doing. You can just let the evaluation expire and nothing will change for you.
