Date/Time: Thu, 26 Dec 2024 14:12:54 +0000
VbP Study on TPO Chart for just the Current Session and not fully right aligned
View Count: 154
[2024-10-27 20:49:45]
User302605 - Posts: 25
On a TPO Chart, I would like to draw a Volume Profile for just the Current Session to the right of the Current Session's TPO and not fully aligned to the far right of the chart. When the VbP study is Based On TPO Chart, it creates Volume Profiles for each TPO. The positioning of the Current Session's Volume Profile is ideal in that instance, but I do not want to also see Volume Profiles for all of the other TPOs, just the Current Session's. On the VbP Study, when I Set as Independent Volume Profile for TPO Chart, I can plot just the Current Session's Volume Profile, but only fully far right aligned. This conflicts with other labels I have on the far right of the chart. Is there anyway on a TPO chart to draw a Volume Profile (VbP) for just the Current Session located just to the right of the TPO chart and not fully aligned to the far right edge of the chart?
Thank you in advance for any feedback.
[2024-10-28 14:56:10]
John - SC Support - Posts: 36850
There is not a way to do this. What you are seeing are the options that are available.
[2024-10-28 15:09:22]
Hi John, thank you for your prompt reply.
