Date/Time: Sat, 12 Sep 2026 21:46:35 +0000
Problem with chart
View Count: 479
| [2024-10-27 00:06:01] |
| User930734 - Posts: 1 |
Hello , since I opened account the main screen is black, doesn't display any charts, I try everything, all settings , all procedures for opening any charts and still screen stays black, also on the first day when I was downloading Sierra Charts it supposed to also be able to download Foundation DOM Chartbook but same - nothing happen
| [2024-10-28 14:12:32] |
| John - SC Support - Posts: 47854 |
You are on a trial and as such you have limited data you have access to. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
