Date/Time: Mon, 23 Nov 2026 19:17:46 +0000
New study for users - Copying all user access from another one
View Count: 754
[2024-10-26 11:41:52]
User361939 - Posts: 170
How can i in fastest way give access to users for my new study that i want to distributed? Access will granted for users who have access to other study. Can I export and import list? what is the best solution?
Date Time Of Last Edit: 2024-10-26 11:44:04
[2024-10-27 17:52:27]
John - SC Support - Posts: 48621
There is not a way to export and import the list of users for a custom study. You would have to re-enter the Account Names manually.
[2024-10-28 13:46:14]
Would you consider adding such option for those who develope and distributed sierrachart studies?
[2024-10-28 15:24:54]
This is not something we can get to any time soon.
[2024-11-05 15:13:49]
Sierra_Chart Engineering - Posts: 25466
We will see about adding functionality to import and export a list of users for custom study authorization.
[2024-11-05 15:16:33]
Super info, waiting for info when it will be ready.
[2026-10-06 22:29:57]
Is it working now? I don't see any option with exporting "users". How can i quikly add my users to new study? instead manually copy pasing everysingle one of them?
Regards
[2026-10-07 00:27:20]
User719512 - Posts: 546
There are a couple of options:
(1)
Put both studies in the same DLL. One source file, one SCDLLName("") and add your scsf_Study1() and scsf_Study2() functions.
-> Uses existing user list
(2)
Use the web API from a python script for example to get all users for Dll1 and set them for Dll2.
Sierra Chart Website APIs: Manage Custom Studies Users
-> You can control each DLL user list independently
Your favorite AI like Grok should be able to assist you with either.
[2026-10-07 00:52:09]
Yes, this is what we were going to recommend:
