Date/Time: Wed, 27 Nov 2024 12:34:28 +0000
hide chart drawings default
View Count: 940
[2014-09-07 18:01:08] |
User57562 - Posts: 98 |
It seems that "hide chart drawings" defaults to On. Please let me decide. I want it off until I choose, so I see markups, if any, on a newly loaded chart. "Hide" should be a sanity check before EAL. I have ECD, EAL, ESD, HCD on toolbar, but easily forget that. |
[2014-09-07 19:16:28] |
It is off by default and what this indicates is that you are running the CLR version and missing the spreadsheet component file, which is causing a memory corruption. Update Sierra Chart with Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-07 19:24:53] |
What is "CLR version"? I have yet to try spreadsheet.
[2014-09-07 19:34:56] |
OK, updated thru HELP. Attached image shows "Hide Chart Drawings" defaulted to on after restart, but it was off before restart/update. |
HideChartDrawings.png / V - Attached On 2014-09-07 19:32:35 UTC - Size: 54.64 KB - 343 views |
[2014-09-07 20:47:23] |
Uncheck Chart >> Hide Chart Drawings. Select File >> Save. Select File >> Close Chartbook. Reopen the Chartbook. The option should be disabled. We see no reason for a problem. We have never heard of such a problem with this before and we see no reason for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
