Date/Time: Sun, 24 Nov 2024 18:54:42 +0000
Mapping IBKR Option Symbols
View Count: 82
[2024-10-25 16:29:51] |
User769783 - Posts: 182 |
I know options trading is limited, but if I have an accnt with IBKR linked to Sierra, can I view their options in Sierra through some sort of mapping or something like that? Thanks
[2024-10-25 17:17:49] |
You have to enter the symbol in Sierra Chart to be the symbol that Interactive Brokers uses. Refer to the following for what we know on this (but you should check with Interactive Brokers on this): Interactive Brokers Symbols: Options Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
