Date/Time: Sun, 24 Nov 2024 18:41:40 +0000
GEZ24-CME
View Count: 95
[2024-10-25 14:08:14] |
thenotoriousjq - Posts: 4 |
I can only see data up to June 2023, Can you check my current subscription to see if this symbol is covered, I have live denali real time data so i dont know what the issue is
[2024-10-25 15:55:24] |
That was the last trading for that product. Refer to the following for some information related to this: https://www.cmegroup.com/media-room/press-releases/2023/4/24/cme_group_completeskeymilestonesinconversionofeurodollarfutureso.html For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
