Date/Time: Sun, 24 Nov 2024 18:41:34 +0000
DOM text is blurry and background changed colors
View Count: 78
[2024-10-25 13:43:00] |
ZeeMar - Posts: 3 |
screenshot attached This morning I came to the computer -- Sierra had been open overnight -- and for unknown reasons my DOM has changed some of the background colors (they are usually yellow and blue, not brown and yellow), and the text appears blurry. I tried closing and restarting Sierra but the problem remains. I googled the issue but nothing similar comes up. Otherwise the trading DOM seems to function fine. How do I restore the appearance to normal? |
ScreenShot121.png / V - Attached On 2024-10-25 13:38:43 UTC - Size: 66.38 KB - 22 views Attachment Deleted. |
[2024-10-25 15:50:31] |
In the image, everything looks fine. There is no blurriness and the colors are blue on the top and beige on the bottom. We can not help with blurriness, something like this would be an operating system issue. As to the colors, there is no reason for them to change. But you can change them through the following setting and the one below it: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Ask Background For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-25 17:01:26] |
ZeeMar - Posts: 3 |
I rebooted my PC and it resolved. Thank you
