Date/Time: Fri, 22 Nov 2024 00:12:00 +0000
Footprint time reach
View Count: 60
[2024-10-25 06:41:43] |
User318857 - Posts: 11 |
on my footprint, is there a way to arrive at the present moment without having to scroll to get there? On all my charts it goes to the present moment, but on the NQ it systematically stays stuck at the date and time of the moment when I previously closed SC. |
[2024-10-25 14:43:00] |
John - SC Support - Posts: 36203 |
All charts should open to the Date/Time that they were set to at the time the Chartbook was saved. Sow hat you are seeing with NQ is what should be occurring with all your charts. Although if a chart is scrolled to the end, then it will continue to be showing the most current bar. You can always select the "End" key to jump to the most current bar in a chart. There are also menu options for "Chart >> Go To End" and "Chart >> Go to Beginning" which also show the keyboard shortcuts setup for these. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
