Date/Time: Wed, 27 Nov 2024 20:50:58 +0000
Issue with Draw Style
View Count: 1290
[2014-09-07 09:46:27] |
sampater - Posts: 244 |
Sierra Chart Engineering, There is a issue with Draw Style: every kind of Fill, Bar Top, Bar Bottom, Box Top, Box Bottom, Candle Body Open, Candle Body Close. If scroll back, is drawing and displaying value of next bar after current visible index. It's misguided and inconsistent with another Draw Style. See pic below. Best regards, Marek |
DrawStyle.jpg / V - Attached On 2014-09-07 09:39:41 UTC - Size: 83.6 KB - 434 views |
[2014-09-10 04:59:15] |
This will be solved in the next release.
[2014-09-11 20:05:18] |
It works fine now. Thank you. But there's another issue with Draw Style Fill to Zero and Transparent Fill to Zero. This issue is only in a case when the Subgraph is used with a condition with the sc.GetBarHasClosedStatus(sc.Index) == BHCS_BAR_HAS_CLOSED. Then is drawing a value 0 on the current bar Index, even if sc.Subgraph.DrawZeros = false. If scroll back, every thing is okey. On the attached picture in the Chart Region 2 i 3 there are the same studies. Only different is another Draw Style. Best regards, Marek Date Time Of Last Edit: 2014-09-11 20:08:04
FillToZero.jpg / V - Attached On 2014-09-11 20:02:45 UTC - Size: 63.07 KB - 372 views |
[2014-09-17 17:01:09] |
We will be looking into this.
[2014-10-05 15:37:22] |
Sierra Chart, Is there any chance to resolved the issue from post #3? Cause of this issue can't display correct subgraph's value on the Value Scale, because always is displayed zero. Thank you for the consideration my request. Marek |
[2014-10-05 18:09:51] |
We have not had time to get to this yet.
[2014-10-09 04:58:58] |
In response to post #3, this will be solved in version 1200 . We were not able to test this, so let us know if you still see this issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-09 04:59:15
