Date/Time: Thu, 21 Nov 2024 23:40:51 +0000
6E / M6E DOM shows invalid Prices
View Count: 112
[2024-10-24 18:07:16]
User388548 - Posts: 3
I followed the Steps to setup 6E / M6E Symbol. The Orders seem to be correctly placed. But the DOM shows invalid prices. See Screenshots (ChartSettings and DOM).
Regards,
Markus
imageBild_2024-10-24_200442218.png / V - Attached On 2024-10-24 18:04:49 UTC - Size: 36.09 KB - 23 views
imageBild_2024-10-24_200531437.png / V - Attached On 2024-10-24 18:05:34 UTC - Size: 38.74 KB - 21 views
[2024-10-24 18:51:23]
John - SC Support - Posts: 36203
Why do you have your "Real-Time Price Multiplier" and the "Historical Price Multiplier" set to 0.0001? These should be set to 1.0.
Date Time Of Last Edit: 2024-10-24 18:51:34
[2024-10-24 19:05:06]
Hi John,
these values were set automatically after selecting the symbol. When I change them to 1 then the Chart's price scale shows wrong values and the DOM is unchanged (see screenshot):
Regards
imageBild_2024-10-24_210455941.png / V - Attached On 2024-10-24 19:04:57 UTC - Size: 65.66 KB - 20 views
[2024-10-24 19:38:45]
Sorry, yes that is correct for that symbol. Please set those to be "0.0001" again.
Please check those values in the Trading DOM and make sure they are set correctly there as well. Be sure you open the "Chart >> Chart Settings" for the Trading DOM directly on the Trading DOM. These are separate settings from the chart.
[2024-10-24 20:14:01]
Thank you, that fixed it :-)
Regards
