Date/Time: Fri, 22 Nov 2024 00:04:40 +0000
Difference between 3 moving averages
View Count: 71
[2024-10-24 18:04:45]
User993440 - Posts: 16
Is it possible to measure the max difference between the highest and lowest out of 3 moving averages. So for instance if:
MA1 = 5650
MA2 = 5600
MA3 = 5550
The max difference is 100. The order the MA's are in doesn't matter.
[2024-10-24 18:50:03]
John - SC Support - Posts: 36203
You would need to use the Spreadsheet Study to do this. Refer to the following:
Overview of Spreadsheet Studies
