Date/Time: Fri, 27 Dec 2024 15:46:24 +0000
New Computer
View Count: 96
[2024-10-23 16:30:44] |
Robert Wojczak - Posts: 144 |
I'm going to be getting a new computer. How do I transfer all my chartbooks onto the new system? Thank You |
[2024-10-23 18:09:00] |
John - SC Support - Posts: 36880 |
Refer to the information at the following link. The particular method you choose to use is up to you: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
