Date/Time: Fri, 27 Dec 2024 05:38:14 +0000
Is it possible to (mirror&flip) the charts as a study?
View Count: 90
[2024-10-23 16:13:33] |
User429142 - Posts: 44 |
Over the years of no margin trading I became long-biased and try to go long when the market indicators and trend is telling me it's going lower. I believe I can overcome this if I can mirror & flip the chart in a study. Is that possible to do? Then it would be easier for me to identify my pitfalls. IE: if this downtrending marketing was really going up I wouldn't be trying to short in this spot so its not ideal to be longing the non-mirror flipped chart (the real one). |
[2024-10-23 18:00:56] |
John - SC Support - Posts: 36873 |
There are three options for how to do this: 1. Use the "Chart >> Chart Settings >> Symbol >> Invert Prices". Refer to the following: Chart Settings: Invert Prices (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) 2. Use the study "1 divided by Price". Refer to the following: 1 Divided by Price 3. Use the study "Multiply Bars by -1". Refer to the following: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=189#Multiply_Bars_By_-1 You will not be able to send orders from these charts, so be careful in that regard. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
