Date/Time: Fri, 27 Dec 2024 08:16:50 +0000
Problem with coloring background between 2 moving average
View Count: 122
[2024-10-23 06:57:37] |
User823328 - Posts: 27 |
Hello i try to color background between 2 moving average using the study subgraphs référence but i dont know why the colored background don't match with the Moving average (as you can see on the attached screenshot). Can you help me to solve this issue please ?
Date Time Of Last Edit: 2024-10-23 06:59:48
Capture d'écran 2024-10-23 085323.png / V - Attached On 2024-10-23 06:59:28 UTC - Size: 44.07 KB - 51 views Attachment Deleted. |
[2024-10-23 14:44:15] |
John - SC Support - Posts: 36873 |
You need to set the scale for the "Study Subgraphs Reference" to be either "Automatic" or "Same as Region". By default it is set to Independent. Refer to the following: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
