Date/Time: Fri, 27 Dec 2024 15:31:05 +0000
Inserting Chartbook on my Sierra Chart
View Count: 99
[2024-10-22 19:47:27]
usataFX - Posts: 1
I am new to Sierra Chart and this first experience is bad, I have been trying to add a chartbook and it doesn't go through. I t says "The chartbook file is not compatible. Contact Sierra Chart support for help with converting it."
So I am gonna be needing some assistance with getting it right please. I would really appreciate as I am trying to build my trading career and this is a bad way to start.
[2024-10-22 19:50:51]
John - SC Support - Posts: 36877
You should go to the source of the chartbook and have them get you an updated version.
But, you can go through the following instructions to update the chartbook:
Chartbooks (Workspaces): Opening Older Chartbooks
