Date/Time: Fri, 27 Dec 2024 05:25:44 +0000
HIdden Charts
View Count: 101
[2024-10-22 19:31:43] |
User841161 - Posts: 225 |
Is there a way to delete multiple hidden charts. The only way I have found to do it is attach chart(which opens chart) and close(remove) it, but this method only does one chart at a time.
10-22-24.PNG / V - Attached On 2024-10-22 19:31:35 UTC - Size: 155.17 KB - 36 views |
[2024-10-22 19:43:17] |
John - SC Support - Posts: 36873 |
There is not a way to delete multiple charts, hidden or otherwise. You have to somehow have the chart active and then use one of the methods to close it.
