Date/Time: Mon, 05 Oct 2026 01:12:01 +0000
DOM Update
View Count: 486
[2024-10-22 11:45:35]
User131975 - Posts: 78
Hi I have read a lot in the DOM documentation and there it is recommended to set the DOM to 100+ ms update interval. But what would you recommend to someone who scalps? So watching the order flow
[2024-10-22 15:00:45]
John - SC Support - Posts: 48095
You probably want to set it to the lowest value possible - which would be 10. But the exact choice of what to use is a personal decision.
