Date/Time: Fri, 25 Oct 2024 23:51:04 +0000
Missing data
View Count: 25
[2024-10-22 05:32:19] |
Galmik - Posts: 29 |
Hallo! I am missing data from yesterday session on ESZ4. There is no data after 19:00 - 22:30 EST I attach photo Please tell me how i can restore lost data Thank you https://www.sierrachart.com/image.php?Image=1729574991599.png |
[2024-10-22 14:28:03] |
John - SC Support - Posts: 35527 |
We can not tell if there is data or not from the image you provided. It is best to look at a standard candle chart with a time based period to see if you are actually missing data. If you are missing data for a time period, then refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
