Date/Time: Fri, 25 Oct 2024 23:50:50 +0000
[User Discussion] - Dragging Limit Orders on Chart
View Count: 69
[2024-10-21 22:52:06] |
ycomp - Posts: 310 |
if you have a Target Limit order at +10T... on the chart... and price is at +7T right now, and you drag it down below +7T, will it get filled at +7T or at something lower?
[2024-10-22 14:41:59] |
Sawtooth - Posts: 4099 |
It will get filled at Market.
[2024-10-23 16:18:31] |
so if I dragged the limit order or simply clicked "BE" (Break Even), then it would execute at the same price? (which is market)?
[2024-10-23 18:02:16] |
John - SC Support - Posts: 35527 |
Breakeven is different. Breakeven moves the Stop to the point where you would end up with zero profit/loss (ignoring fees and commissions). So this will not necessarily move it to a position where the position would be closed, unless you were at a loss at the time.
[2024-10-25 12:11:22] |
I didn't really explain that well it should have been a separate question really. What I mean about Break/Even is if you are underwater.. like say -2T and you press B/E, then will it trigger a market order? |
[2024-10-25 15:15:01] |
Yes, it is the same as manually moving the stop to above the current price. It will then fill at the Market price.
