Date/Time: Fri, 22 Nov 2024 06:39:37 +0000
Key to Line up Prices on Charts
View Count: 87
[2024-10-21 21:35:12]
ycomp - Posts: 316
You can use a key to line up current prices on the DOMs, is there a way to do this with charts as well?
If not, can this be a feature request?
[2024-10-22 13:50:35]
John - SC Support - Posts: 36203
We are not sure what you mean by a "key".
If you are referring to the "Chart DOM Recenter Line", then this can be used on a Chart DOM, the only requirement is that the Chart Scale Setting has to be set to "Constant Range".
