Date/Time: Fri, 22 Nov 2024 05:49:26 +0000
Showing the study value in Chart/Tool Value Windows for a hidden study
View Count: 57
[2024-10-21 20:17:48] |
User238701 - Posts: 158 |
Hi I have ATR on my daily chart in Region 2 as a line chart. But it is taking space, so I want to hide the study. I still want to see the value of ATR for each daily candle as I hover my mouse on that particular daily candle. Is this possible? Thanks |
[2024-10-21 20:48:26] |
John - SC Support - Posts: 36203 |
You would have to use the "Tool Values Window" in order to view the ATR information - you can not do this with the "Compact Tool Values Window". With the ATR hidden, make sure the option for "Display Values when Hidden" is enabled. Refer to the following: Chart Studies: Subgraphs Tab >> Display Values When Hidden For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
