Date/Time: Thu, 31 Oct 2024 10:12:48 +0000
Not able to load 15 range on footprint chart
View Count: 43
[2024-10-21 19:37:38]
User558370 - Posts: 4
For the first time when I loaded Sierra, the footprint chart didn't show up, and after I loaded it, I was only able to see 1 minute on the footprint chart. I normally use 15 range and it's the default, but every time I switch it in settings, it goes back to the default 1 min chart.
imagefootprint not working.JPG / V - Attached On 2024-10-21 19:37:33 UTC - Size: 327.34 KB - 13 views
[2024-10-21 19:38:17]
John - SC Support - Posts: 35639
Refer to the following:
Unable to Change the Bar Time Period for Charts
