Date/Time: Thu, 31 Oct 2024 10:12:41 +0000
Two Data Feeds, Same Broker
View Count: 47
[2024-10-21 05:25:36]
User453661 - Posts: 1
Apologies if this has been asked before. I’m with EdgeClear but use the Denali data feed with Teton routing and get all my CME data through Denali. I’d like to also trade commodities through ICE. EdgeClear offers ICE data through CQG.
I want to keep Denali for CME but use CQG for ICE. Can I use two different data feeds with the same trading account and broker on one instance of SC or do I have to install a second instance? Would I just need to switch data feeds in global data settings whenever I switch between CME and ICE? Anyway I can have both open at the same time?
[2024-10-21 16:05:31]
John - SC Support - Posts: 35639
You need to have a second installation of Sierra Chart to do this. You will also need a different trading account with Edge Clear in order to do this, as you can not have the same trading account setup to use both the Teton Order Routing Service and CQG.
Follow the instructions at the following link to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Then, in that second installation, follow these instructions to connect to your CQG account with Edge Clear:
CQG Trading Platform Service: Setup Instructions
