Date/Time: Fri, 22 Nov 2024 06:31:37 +0000
Limit Study Days
View Count: 115
[2024-10-20 10:57:36]
User131975 - Posts: 78
Hello, I have a 30m CHart that loads 400 days and on which I create analyzes and zoom in closer when trading to always have a larger picture. But I also have things like the volume bars and RVOL as a study. Is there a way that I can limit them so that they are only displayed for the first 10 days? Everything else is bad for the eye and above all unnecessary resources.
[2024-10-21 15:20:54]
John - SC Support - Posts: 36203
The main way to limit the display of certain studies is if the study has a control for the number of days to calculate. The Relative Volume has the Input for "Period - Days to Include" that lets you control this. The Volume study does not have an Input for this, so it is going to show for all days.
If you want to not display the information for a study beyond the most recent 10 days, then you would need to add a Spreadsheet Study to the mix and use the Spreadsheet Study to control the amount of data shown. You do this by setting the "Number of Rows" input to the number of bars for which you want the data displayed. Then setup the Spreadsheet to display the that study as you want. Refer to the following:
Spreadsheet Study Inputs: Number of Rows
