Date/Time: Wed, 27 Nov 2024 12:29:32 +0000
Market Stats & Data Feeds
View Count: 1041
[2014-09-06 03:17:44] |
User76044 - Posts: 11 |
Hi Is it possible to run two data feeds at once, for example can sierra chart use CQG for futures tick data and SierraChart MarketStats for the market statistics in realtime? Additionally I would like to see some examples of SierraChart's Market Stats TICK-NYSE, as my trial has expired is it possible for you to add a day of usage or to attach a picture of 1 minute bars from the NYSE-TICK from 28 August 2014? Many thanks, Ben |
[2014-09-06 20:57:08] |
Yes. This is how the market statistics data feed works. It is fully integrated with all trading services including CQG.Here is the documentation for the market statistics data feed: Sierra Chart Market Statistics We are adding 3 days of usage time to your account now. You will need to restart Sierra Chart if it is running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-06 21:14:45] |
Hi Thank you, I really appreciate that. As CQG provides market statistics themselves (inlcuding NYSE-TICK), if my futures data feed is CQG how can I be sure that the market stats I am seeing are calculated by SierraChart and not from CQG? How often does the SierraChart NYSE-TICK calculate its reading? Does it calculate each second or does it record every tick? Is there an option to customise this to ensure the NYSE-TICK is including all data and not missing any by performing the calculation at set intervals? Thanks, Ben |
[2014-09-06 21:48:12] |
The symbols that Sierra Chart uses most likely would be different than CQG. When you are using a Sierra Chart market statistics symbol, the data will definitely come from the Sierra Chart market statistics data feed. The calculations are done twice a second. And is designed not to miss any highs or lows. So the calculation frequency and transmission of data will increase if necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-06 21:49:17] |
That is excellent thank you
