Date/Time: Thu, 31 Oct 2024 10:12:59 +0000
DVP doesnt Sync
View Count: 58
[2024-10-20 09:57:33]
User131975 - Posts: 78
I have configured the DVP tool as described. I should create an extra study where I build the VP the way I want it and then save it in the Global Settings under the Configs. When I draw it in my 405m chart I can see it but not in any other chart (although they are synchronized). Is this normal? I want to see it in the other charts as well.
[2024-10-20 10:01:46]
Sorry i forgot to upload the pngs
in the “405m DVP” png you can see that I have drawn in the volume profiles. But on my 30m chart I don't see it where it should be.
And I see the study in my 405m CHart as shown in the last picture, but I don't see it in my 30m chart.
I just found out that no matter where I enter it, it is not displayed in any other chart. Is that how it should be?
Date Time Of Last Edit: 2024-10-20 10:11:25
image405m DVP.png / V - Attached On 2024-10-20 10:01:04 UTC - Size: 78.54 KB - 16 views
image30m Chart.png / V - Attached On 2024-10-20 10:01:07 UTC - Size: 137.27 KB - 14 views
image405m Studys.png / V - Attached On 2024-10-20 10:03:05 UTC - Size: 91.66 KB - 15 views
[2024-10-21 14:53:59]
John - SC Support - Posts: 35639
The Drawn Volume Profiles can not be copied to another chart. They are different from other drawing tools, in that they actually create a "Volume by Price" study, you are just defining the study by drawing the box where you want it.
