Date/Time: Thu, 31 Oct 2024 10:12:39 +0000
connecting to IB and trade asian futures
View Count: 89
[2024-10-19 07:05:33] |
User894728 - Posts: 9 |
hello there, i am new here and have sevral quick questions 1. if i subscribed data in IB, does it flow into sierra? 2. can i placing oders on HSI futures using sierra and send it to IB? 3. does sierra support scaling in and out? lets say i have longed 3 futures and need to scale out 1 at cost+60 points, another at cost+70 points, also the original bracket orders needs to be auto adjusted can this be done Thank you Date Time Of Last Edit: 2024-10-19 07:06:54
[2024-10-20 01:18:40] |
John - SC Support - Posts: 35639 |
1. Yes. Refer to the information regarding connectivity between Sierra Chart and Interactive Brokers at the following link. Note the Setup Instructions on the page: Interactive Brokers Trading Service 2. Yes. 3. Yes. Refer to the following, noting the "Scaling In" and "Scaling Out" sections on the page: Attached Orders For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-21 00:26:31] |
Thanks John For trial version, can i test these features on HSI futures? if not, what do i need to do |
[2024-10-21 00:39:05] |
Sierra_Chart Engineering - Posts: 16766 |
We set your account to Service package 11 which can connect to interactive brokers.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-21 00:39:21
