Date/Time: Fri, 22 Nov 2024 06:45:42 +0000
[Programming Help] - ACSIL GOTO DATE_TIME FUNCTION
View Count: 106
[2024-10-18 10:57:07]
aknsyu71@gmail - Posts: 54
Is there a ACSIL function or variable to control the first bar DATE&TIME displayed in the chart and the last bar DATE&TIME
I dont mean to load data but rather to display a specific DATE&TIME range.
[2024-10-18 13:40:49]
John - SC Support - Posts: 36203
Within Sierra Chart, the loading and displaying are the same thing. So if you loaded data for 5 days, you will get 5 days of data showing. If you use the "Date Range" for the days to load, then this sets the start and end date for the data that is displayed.
ACSIL can control both of these options. Refer to the following:
ACSIL Interface Members - Variables and Arrays: sc.LoadChartDataByDateRange
[2024-10-18 15:54:51]
thank you but not what I was after, let me try explain again.
I loaded 5 days of data and now Id like to program a button to show Day1 9:30 to 11:30 then at a press of the button it goes to Day2 9:30 to 11:30 and so on.
