Date/Time: Fri, 03 Jan 2025 00:36:12 +0000
Main Sierra Chart Window is missing
View Count: 115
[2024-10-17 21:38:49]
User234371 - Posts: 2
My main Sierra Chart window is missing. All other windows are open in my chart book. When I hover over the Sierra Chart Icon at the bottom in Windows 11, the left most item was my main Sierra Chart Window. That is now not there anymore. My PC froze up on me today and now this is what I got going on. Everything seems to be working except this main window that has all the tabs on the bottom, main Sierra Chart functions is hiding somewhere. I was wondering how to I get that to show up again?
[2024-10-17 23:10:07]
John - SC Support - Posts: 36966
It should not be possible (from Microsoft Windows) perspective for that main window to not be showing in the Taskbar for your system. And it must exist, otherwise the entire Sierra Chart program would not be running.
The first thing to try is to review the items at the following link for how to move a window from off-screen, as we assume that this is the situation:
https://www.windowscentral.com/software-apps/windows-11/how-to-move-a-window-thats-off-the-screen-on-windows-11
Otherwise, you would have to use the Taskbar to stop Sierra Chart and then start it again (or reboot your system). You will lose any changes to your charts since your last save (or last auto-save, if setup) when you do this.
