Date/Time: Thu, 31 Oct 2024 10:12:42 +0000
Can I share data/charts between 2 concurrent Sierra instances?
View Count: 51
[2024-10-17 10:00:35] |
User837624 - Posts: 17 |
Hi, I have 2 instances of Sierra installed and working. One is using SC Data and the other CQG+Denali. Question: is it possible to show a chart or chartbook from SC Data instance within the CQG+Denali instance? I'd like to keep one instance minimised while another instance would have several charts/chartbooks coming from the minimised instance. Basically to make it easier to navigate between and compare price on many charts. How can this be done? Thank you |
[2024-10-17 14:52:42] |
John - SC Support - Posts: 35639 |
There is not a way to do this exactly, in particular having the other charts "within" the instance you are wanting. What you can do is to detach the charts that you want from the instance you want to keep minimized, and then those charts will still be visible on your desktop. Refer to the following: Window, CB and CW Menus: Detach/Attach Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
