Date/Time: Thu, 31 Oct 2024 10:13:05 +0000
Attach a Sub Account
View Count: 68
[2024-10-16 15:16:00] |
User769783 - Posts: 182 |
How can I attach a sub account for use, that I have with AMP? My main account is trading on a vps and I want to log into the sub account from my home pc. I use Teton if that helps. Thanks.
[2024-10-16 16:26:02] |
John - SC Support - Posts: 35639 |
It looks like you are using our Teton Order Routing Service for your account at AMP. As such, your trading accounts will show in your Trade Window where you can select which one is being used for each chart. Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-16 17:43:05] |
Okay, yes, Im familiar, but I cannot have two separate log in locations, using the sub account as the other log in from home pc? I ask because a rep at AMP said you folks may be able to do this for me.
[2024-10-16 19:24:36] |
You can connect to the same Teton setup that you have from both locations and both locations will have both accounts showing. The one thing you need to be aware of is that if you are using both computers at the same time, then you would need to pay a second set of exchange fees. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
