Date/Time: Fri, 22 Nov 2024 04:05:37 +0000
thought you might want to see chart settings for m6e
View Count: 88
[2024-10-16 09:21:38] |
User849502 - Posts: 345 |
more info still can't enter an order. This is yet another new dom I created. same problem
[2024-10-16 15:05:13] |
John - SC Support - Posts: 36203 |
We need more information. What exactly is occurring? Are you using a "Trade and Current Quote symbol"? If so, what is it set to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-16 15:10:08] |
Hi, It is all good now mate! I simply restarted after new version installed. sorry had sent this way earlier. ALL GOOD! thank you |
