Date/Time: Fri, 22 Nov 2024 04:11:10 +0000
Problem With Loading Candles In Particular Study Set
View Count: 69
[2024-10-16 05:16:20]
PolandSpringer - Posts: 30
For one of my execution charts I was using an overlay study to overlay a line on close from a 500volume chart. I had candlesticks hidden in the chart settings.
I have been trying to switch this back to showing candles from the execution chart itself and not the overlay study. If I enable by selecting candlestick bars under graph draw type nothing shows on the chart. I have tried hiding the overlay study and removing it. Neither work.
I saved the studies as a collection (after removing the overlay study), opened a new chartbook and loaded a fresh chart up. If I apply the study set to a chart in a completely separate chartbook it still will not load the candles.
If I hide every single study in the study collection it will not load any candles. Once I load this study collection into any chart, it is impossible to get candles/lines/any "graph draw type" to appear until I select a completely different study collection.
I included an attachment of the study collection. Any help would be appreciated.
Private File
[2024-10-16 14:59:02]
John - SC Support - Posts: 36203
The problem is your "Numbers Bars" study. It is not set to show anything - you do not have any text or background coloring set, so nothing is being drawn.
Also, if you Hide a Numbers Bars study, the system will still not display the candles. You need to remove the Numbers Bars study in order to have the candles showing again.
