Date/Time: Wed, 27 Nov 2024 13:03:13 +0000
If a question goes unanswered
View Count: 884
[2014-09-05 19:27:05] |
ripsdips - Posts: 143 |
If a question goes unanswered, should I go with the assumption that the subject topic has no answer or can not be supported?. I asked a question 48 or 72 hours ago and I have not received a response, that's the reason for this post. Thanks.
[2014-09-05 19:43:59] |
There are several general possibilities. We are getting too many questions from an account and we do not deem them as critical to be answered, or the answer is difficult, or we consider it outside the scope of our support.
