Date/Time: Fri, 22 Nov 2024 06:25:53 +0000
real time data on a sim account
View Count: 109
[2024-10-15 20:29:58] |
User496868 - Posts: 18 |
is it possible to get real time live data on a demo/simulation account and if yes how?
[2024-10-16 14:13:48] |
John - SC Support - Posts: 36203 |
We need to know the exchanges for which you are wanting real-time data.
[2024-10-17 18:07:16] |
i want for es and nq
[2024-10-17 18:36:07] |
In order to get the real-time data for the CME Group at the non-professional rates, you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Once you understand the above, and have it worked out, then you can follow the instructions at the following link to setup the data for the CME Group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-18 08:02:12] |
so there is no way to get real time data on a sim account?
[2024-10-18 13:24:51] |
Sierra_Chart Engineering - Posts: 17143 |
You can get real-time data. But all of the information related to this is explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
