Date/Time: Mon, 25 Nov 2024 14:15:54 +0000
Filling time - time between button is pressed and order is filled
View Count: 82
[2024-10-15 16:12:37] |
User308424 - Posts: 70 |
Hi there SC support team, is there any setup that might decrease time of an order fulfilment? I scalp, sometimes it takes up to 2 seconds to be filled and with volatile market it causes an issues. Noticed that its much worse when market is volatile, before open is better but still not instant. Chart update interval? Data packages? Anything that might help? Thanks! |
[2024-10-15 16:26:24] |
Start by referring to the following: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading But, there is still going to be the factors of latency to your trading service provider and then their latency to getting orders to the market. If you are trading the CME Group, then we recommend using our Teton Order Routing Service to get very fast response times (at least from the time the order is received until it gets to the exchange). Refer to the following: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
