Date/Time: Fri, 20 Sep 2024 01:03:46 +0000
вопрос о Packages
View Count: 942
[2014-09-05 16:41:09] |
User78914 - Posts: 2 |
Добрый день подскажите если я приобрету Packages 2, смогу ли я торговать фьючерсы c чарта и пользоваться OCO ордерами если нет то подскажите какой минимальный Packages мне нужен, чтоб была возможность торговать все остальное TPO, Number Bars, мне не нужно... С уважением Сергей... |
[2014-09-06 20:58:44] |
For support for futures symbols charting and OCO orders, you will need Sierra Chart service package 1. You can also use package 3 or 5. However, package 1 will be fine. Keep in mind that you need to have a source for the futures data. Refer to this page for more information: http://www.sierrachart.com/index.php?page=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
