Date/Time: Fri, 22 Nov 2024 10:29:08 +0000
Symbols
View Count: 62
[2024-10-14 16:59:20]
User995401 - Posts: 1
I have recently start using Sierra Charts and in the process of setting up connection and data feed.
My current broker is AMP and I am using CQG routing.
When it comes to data feed I selected 'Denali Exchange Data Feed CME / CBOT / NYMEX / COMEX Exchanges' for $5.5 a month
I am looking to find WTI oil CL symbols that are either CLXXX_FUT_CME or CLXXX_NYMEX but what I was only able to see find is F.US. CLEX24
Could you tell me why am I unable to find these 2 symbols and what is the difference to F.US. CLEX24?
Kind Regards
Damian
[2024-10-14 17:25:26]
John - SC Support - Posts: 36203
Every trading service uses a different set of symbols. F.US.CLEX24 is the CQG symbol for WTI Oil. Whereas CLX24_FUT_CME is the Teton Order Routing symbol for this same contract.
Since you are using CQG for your order routing, you need to use the CQG symbols. You will find the appropriate symbols in the "File >> Find Symbol" window.
Note that you will be getting your data from our Denali Exchange Data Feed, even though you are using CQG for your order routing. Refer to the following for more on this:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
